Help With Ring Gear Tooth Pattern (Ford 9")
Old Jan 24, 2008 | 08:57 PM
Procharged GTA's Avatar
Car: 1991 Trans Am GTA Drag Radial Car
Engine: F-2 Procharged 18* 434 sbc on Alky
Transmission: Powerglide,Neal Chance Converter
Axle/Gears: Moser 9" Ford 3.50's,35 spline axle
Hi, I would like to know how you guys think this pattern looks on this 9" ford rearend I'm setting up. We have had it out a few times,and we can't seem to get the howl out of it,it's the worse on deceleration,but can hear it slightly on acceleration. We bought a T&D Machine Pinion Depth Checker,and it shows it needs .048" shim everytime we measure it to get it to the 1.022" pinion depth scribed on the pinion,and that is what it has in it,but still howls,so I figured I would post a couple pictures,and see what you guys think,they might be a little blurry. The backlash is set at .0085". This is a Moser Ford 9" rearend in an 86 Trans Am with 3.70 Motive Performance gears,and a Detroit Tru-Trac. What do you guys think?
The picture on the left is the drive side,and the picture on the right is the coast side. The pictures are way to blurry,it's best to not click on them.
Attached Thumbnails Help With Ring Gear Tooth Pattern (Ford 9")-000_0206.jpg   Help With Ring Gear Tooth Pattern (Ford 9")-000_0209.jpg
Old Jan 24, 2008 | 10:03 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Help With Ring Gear Tooth Pattern (Ford 9")
See if you can post some better pics. From the looks of those, it looks like your pattern is too far out on the gear. (backlash)
Old Jan 25, 2008 | 05:56 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
almost looks as if backlash too little(too tight),heeled on drive and too close(deep) on coast
hectre13
Dec 11, 2023 08:14 AM
Jorlain
Oct 8, 2015 01:57 AM
hectre13
Aug 26, 2015 08:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
