Pressure plate/clutch disc/bleeding
Old Jan 27, 2008 | 09:23 PM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
Probably a stupidly simple question, but should I be able to turn the clutch disc with the pressure plate torqued down?
Also, I bled the clutch hydraulics for about 2 hours today and I only get about 1/2" of fork travel. I did the "open bleeder, press pedal, close bleeder, release pedal" method. I unbolted the slave and pushed the rod in too. I have a brand new aluminum slave, but a used master. No leaks anywhere. Should I keep bleeding, or do I have a bad master cylinder? I'm half-way tempted to just buy the pre-bled LT1 setup from GM just so I don't have to deal with it anymore.
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Stryker412
Sep 20, 2015 06:59 PM
TBRays98
Sep 6, 2015 05:05 PM
