9 bolt or 10
9 bolt or 10
hey i have a 1986 camaro and up until now i thought i had a 9 bolt but someone said i have a 10. can someone help me out. http://i205.photobucket.com/albums/b.../9boltor10.jpg thats a picture of it next to a 9 bolt and 10 bolt gasket
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 9 bolt or 10
No plastic drain plug means its a 10-bolt. Count the number of bolts holding the cover on. 9 bolts means its a 9-bolt rear and 10 bolts means its a 10-bolt rear. That is where they get their name.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1987 IROC
Engine: 383SR
Re: 9 bolt or 10
If you dont have a jack, get your digital camera and start taking pictures from different angles and see if you can count the bolts
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: 9 bolt or 10
I'm sure you could find some wood to back it up on
No Jack
Later
No Jack
Later
Car: 1987 IROC
Engine: 383SR
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Re: 9 bolt or 10
I would agree with the wood statment, but if you get some 2x (at least 2x6)somthing that you can back the car onto, use them like a ramp you will be fine. Just don't be stupid about it. If it's a clutch use chock blocks.
If the top of your driveway if flat then it angles down back it up til your tires are on the edge of the flat part and the back hangs over the angle, then look. (more clearance)
Re: 9 bolt or 10
What do you mean you cant get under the car? My car is lowered and I can still look under the muffler and see the rear end and count the bolts.
Car: 1989 iroc z
Engine: 98 ls1, prcs, btr cam
Transmission: rkt56 6 speed
Axle/Gears: midwest chassis 9 inch 4.30wavetrac
Re: 9 bolt or 10
what is the big difference between a 9 and ten bolt anyway i found out today i have a 9 are the worth anything it has alluminum calipers thanks
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: 9 bolt or 10
The 9 bolts are a little stronger than the 10 bolts, and most of them came with disc brakes. They have a 7.75" ring geat rather than a 7.5". Other than that, there's not much difference. They are hard to find parts for, but 10 bolts are a dime a dozen.
Car: 1989 iroc z
Re: 9 bolt or 10
it has 277 in the rear also internally are they the same like ring and pinion size
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
