POSI or not?
Old Jan 30, 2008 | 12:24 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
POSI or not?
I have a 1989 RS and it had the L03 till this winter... but when i would drive it last summer it would NEVER do a one wheel peel. Not one. and i hear tons of RS's having that problem. is it possible that i have a POSI that the previos owner put it? or can my limited slip be not working right?
Old Jan 30, 2008 | 12:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: POSI or not?
Take the cover off and look, if you really want to know.
Old Jan 30, 2008 | 12:58 PM
v10viper04's Avatar
Engine: LT1, L99
Re: POSI or not?
i don't know what POSI looks like....
Old Jan 30, 2008 | 02:49 PM
Re: POSI or not?
Take a pic and post it; there are people here who can tell you. Make sure you use the flash, and that it shows the carrier's innards, looking inside the little window in the carrier.
While you're there, make a point of counting the ring & pinion teeth, and/or finding the stamping on the edge of the ring, so you know what gear it has; since that's likely to be something you'll eventually be curious about as well.
Old Jan 30, 2008 | 06:54 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: POSI or not?
If you don't know what it looks like do a little research. Also for your education you are writting about a LIMITED SLIP rear and not the slang term Posi.
Old Jan 30, 2008 | 10:46 PM
v10viper04's Avatar
Engine: LT1, L99
Re: POSI or not?
yes i know that...
Old Jan 30, 2008 | 11:53 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Re: POSI or not?
Might wanna check your RPO codes before you tear your diff cover off, might save you some hassle :P
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
