Quick 9 bolt question
Old Jan 30, 2008 | 03:58 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Does a 9 bolt use the same ring gear bolts as a 10 bolt?
Old Jan 30, 2008 | 04:25 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: Quick 9 bolt question
no
Old Jan 30, 2008 | 04:29 PM
Mongoose's Avatar
Car: 90 Formula
What's the difference? Ratech lists the same ring gear bolt for both 9 and 10 bolts on their website?
Old Jan 30, 2008 | 07:47 PM
Engine: ls1, LB9
the head is bigger I belive. I am sure others will "work" kinda like the solid pinion spacer I used in my 9bolt
Old Jan 31, 2008 | 01:07 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Early 10 bolts are 7.5", and later 10 bolts are 7.625". They are interchangeable.
9 bolts are 7.75" and only 9 bolt specific gears will work. If Ratech lists the same gears for both rear ends, they are wrong.
Old Jan 31, 2008 | 05:35 AM
Pat Hall's Avatar
Looked up the specs on each at Randy's Ring and Pinion. The 9 bolt ring gear bolts are 7/16x20 LH thread, the 10 bolt ring gear bolts are 3/8x24 LH thread. Since they're both LH thread, you have to go clockwise to loosen them on either rear.
Old Jan 31, 2008 | 07:40 AM
Mongoose's Avatar
Car: 90 Formula
I'm talking ring gear bolts, not the ring gears.
Old Jan 31, 2008 | 08:24 AM
Mongoose's Avatar
Car: 90 Formula
OK, did some calling around and found that the 9 bolt and 10 bolt do use the same 7/16x20 LH thread bolts. There is also a 3/8x24 LH 10 bolt ring gear bolt as well but for the F bodies they are the same 7/16x20. This also happens to be the same bolt as the 8.5" 10 bolt truck rear end too. Just spoke with Summit and they confirmed all the info so a set of Ratech ring gear bolts is on it's way. ARP has them too but at $75 I went with Ratech since this is a street car. Thanks Pat Hall for the info, that made clearing this up a lot easier.
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
