4th gen or 3rd gen????
Old Feb 3, 2008 | 05:35 PM
1988350bia's Avatar
Car: 1988 camaro SC
Engine: 355 four bolt
Transmission: th350
i have two rear ends relatively near me in my price range. ine is a 1996 z28 rear with 3.23 gears and discs.
the other is a 3rd gen. BW 9 bolt with 3,27 gears and discs.
ive read up on both and i know what i need to do both swaps, im still not sure. help me out.
Old Feb 3, 2008 | 08:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 4th gen or 3rd gen????
The 9-bolt rear end will be stronger, but the aftermarket support is a lot smaller. I would still get the 9-bolt rear.
Old Feb 3, 2008 | 09:35 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
BW also
Old Feb 3, 2008 | 09:57 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
BW 9 is what I would get and run. does the 9bolt have pbr rear brakes? if not I would do the swap to the pbr
Old Feb 4, 2008 | 07:20 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Go with the 9-bolt and if it has the 1989 rear PBR brakes it is a plus.
Old Feb 4, 2008 | 07:28 AM
1988350bia's Avatar
Car: 1988 camaro SC
Transmission: th350
thanks guys. turns out hes going to throw in the m/c and the prop. valve so i think ill do that. and if anyone needs a rear end i have found a bunch in the s/e michigan area let me know. lots of fourth gen. rears with low miles
Old Feb 4, 2008 | 08:32 AM
DJP87Z28's Avatar
You will not need the m/c, just the proportioning valve. But the most important is the the Parking brake cables for that 9-bolt.
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
jbd1969
Aug 17, 2015 07:06 PM
