th350 fluid leak
Old Feb 6, 2008 | 06:52 PM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
th350 fluid leak
hey, i just put a used 305 and th350 in my camaro, and i had to take of oil pan cause the frigging oil seal on the end of the dip stick fell off the attachment, now its leaking tranny fluid. Do you have to put silicone when reusing the gasket? And does the oil pan gasket come with a transgo shift kit, cause i want to be putting one in and might as well if its leaking. Also i believe its leaking from the the speedo cable, i was told their is an o ring that goes in their is this true? if so if i go at gm, can they get me the right one, i don't know what size or anything cause their is none their right now.
Old Feb 6, 2008 | 07:27 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: th350 fluid leak
Stop at a local trans shop. They usually have them in stock.
HikoriYami
Sep 21, 2015 07:11 PM
Stryker412
Sep 20, 2015 06:59 PM
bubbaz28
Sep 18, 2015 02:09 PM
89newfun
Sep 16, 2015 09:28 AM
Numbah-1
Sep 12, 2015 08:57 PM
