View Poll Results: Posi or limited?
Posi
100.00%
Limited
0%
Voters: 1. You may not vote on this poll
posi or limited?
Old Feb 12, 2008 | 04:50 PM
bmxfire37's Avatar
posi or limited?
i belive my 87 firebird has a posi. thats what ive herd is this true?
i just go tthis car to restore and im trying to get as much info as i can.
which is better for street use, and track use
posi or limited?
what are any good or bad sides to either?
witch would you choose?
Old Feb 12, 2008 | 05:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: posi or limited?
Posi is limited slip, limited slip is posi. Whatever you call it, your car might have it, or might not. The best way to tell is to take the cover off and look.
Old Feb 12, 2008 | 05:22 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
the real question is locker or posi (limited slip)
I'm sold on auburn for life!
Old Feb 12, 2008 | 06:10 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
'posi', aka, 'positraction' is merely Chevy's name for limited slip, but it's become such widely known that you rarely hear the official names used by other companies. According to wikipedia:
Pontiac: Safe-T-Track
Ford: Equa-Lock and Trac-Lok
American Motors Corporation: Twin-Grip
Mopar: Sure Grip
Ferrari: E-Diff
Fiat: Viscodrive
TVR: Hydratrak
Oldsmobile: Anti-Spin
Jeep: Trac-Lok (clutch-type mechanical) and Tru-Lok (gear-type mechanical)
Old Feb 12, 2008 | 06:56 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Posi = fancy GM product name
Limitted Slip = Generic Term
They are the same thing.
Take off the diff cover, and look into the center of the carrier, inside the ring gear. If you only see a big pin and some small gears its an open differential (non limitted slip diff) but if you see some springs in there as well, then it is a posi/limitted slip.
Probably time to change that diff oil anyway
KO1
16
Oct 15, 2015 05:00 PM
racereese
Oct 3, 2015 03:46 PM
