350 TPI w/ T-56 swap MPG
Old Feb 14, 2008 | 09:43 AM
Johnknight1981's Avatar
Car: 1989 Chevy Camaro Iroc-Z
Engine: L98 B2L 350 TPI
Transmission: 700R4 auto
Axle/Gears: 2.77
Can anyone post there MPG from there 700r4 to t-56 swap also add what rear gears you used, if you have a stock engine please let me know of the difference you got in your mpg. thanks
Old Feb 14, 2008 | 11:13 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: 350 TPI w/ T-56 swap MPG
I did the swap but don't know the mpg for sure. I would say around 2-4 on the highway.
Old Feb 15, 2008 | 01:20 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I don't recall my auto MPG, but with the t-56 and 4.11's on the highway around 80 I get about 22 mpg. Around town wasn't very impressive I was usually romping on it going from the 2.77 to 4.11's. Engine is basically stock except for full exhaust.
Old Feb 15, 2008 | 07:10 AM
vbMike's Avatar
I got about 20mpg at 75 with my automatic and 3.27 gears
Old Feb 16, 2008 | 08:23 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
T56 and 3.27's with a fresh more-or-less stock 350 tpi... I've seen a best of about 32 MPG on the highway... City is likely below 20.
Old Feb 16, 2008 | 10:40 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Damn, I wonder what I could get with a T-56...
My T5 lo3 gets >30 on the highway, cruising at 75. Like 15 around town tho.
My buddy has a 98 SS LS1 T56 and he can get like 34 on the highway in 6th. He sees around 20 in town, sometimes more.
Old Feb 17, 2008 | 03:04 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Well if you keep the 3.08 setup you'll be like me with 2.77's and will never touch 6th gear, I only hit it around 90 before the rear swap.
Old Feb 17, 2008 | 12:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you want a T56 for the gas mileage and not for the benefit of shifting your own gears, then you're doing it wrong.
Old Feb 17, 2008 | 01:58 PM
Engine: LO3
Well, I bought a T5 car for to be able to learn how to drive clutch real nice. Figured I would never seen 18mpg on the highway. I was surprised to say the least after my first trip on the highway!
BTW I dont consider the T56 the end-all solution. Jeff isnt even happy with the one on his LS1. He said it has quirks, like it wont go into 5th after being in 6th, unless he hits the syncro in 3rd or 4th before goint to 5th. Also, it grinds if you try to shift it too fast in a race.
My T5 isnt a great tranny tho, either. It will randomly grind on the way into gears, it will randomly spit the shifter out of gear while you are driving, it always kicks back on the way into gear, and its always very "clunky" not to mention the annoying gear-meshing noise when cruising in the lower gears!
Old Aug 2, 2008 | 04:39 PM
86transam383's Avatar
Car: 1986 Trans am
Engine: 383ci
Axle/Gears: 2.77/3.45 ready to go in
lol i get near 28mpg on the highway with 2.77 gears and a mild-wild motor. with my 700r4.. i'm going to be doing a t56 swap so i can use the 4.11 gears
88CamZ
Oct 8, 2015 10:29 AM
Luigytico09
Oct 1, 2015 08:46 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Gordonr1973
Sep 29, 2015 11:59 AM
dusterbd
Sep 29, 2015 08:40 AM
