Shimming rear end...Do I...
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Do I remove all play or leave a little as the instructions say in servicing a 9 bolt. It is going to be street/street. Also, what type of rear end fluid should I get?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Shimming rear end...Do I...
What part are you talking about specifically? Backlash, pinion depth, etc?
What kind of posi is in it?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
BW 9 Bolt 3.27 posi. I need to shim the posi cones so my posi works again.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
