GM clutch cylinders
Old Feb 16, 2008 | 07:57 AM
Benny K's Avatar
Car: 91 Z28
Engine: TPI 350
GM clutch cylinders
I used brand new GM clutch master and slave cylinders for my t5 swap...they come as one unit pre bled...
now they squeak pretty bad!
when the car stands for about 1 or 2 days, the first 4 or 5 clutch engagements are absolutely quiet...then it starts to squeak horribly...
I already bled the whole system with DOT4+ fluid cause I assumed that some air is causing this...no sucess with that...
pushed in the slave by hand and lubed the inner surface with some bad *** silicone grease....only a slight change...for a short moment
has anyone experienced the same problem with GM cylinders? It's really pissing me off....they cost a small fortune here and I can't return them (as all parts that are ordered from GM overseas..idiotic)...it's making the car sound like some junkyard scrap car...
Old Feb 16, 2008 | 08:11 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Re: GM clutch cylinders
i hear the cylnders that summit sells are pretty solid?and pretty fairly priced too
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
mfp189
Sep 27, 2015 09:25 AM
