questions on 12 bolt rearend's
Old Feb 18, 2008 | 12:33 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Engine: 350 4-Bolt Main
Transmission: Rebuilt 700R-4
Axle/Gears: 3:42
i was wondering what 12 bolt rearend's i could use under my 86 camaro? do they have to be out of a camaro? i have a 12 bolt out of a 77 chevy 1/2 truck with 3:73 gears and disc brakes is it a do-able job?
Old Feb 18, 2008 | 12:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: questions on 12 bolt rearend's
No junkyard 12 bolt or any other junkyard diff will fit because the third gen needs a torque arm mount. The only 12 bolt you can use is an aftermarket model designed for a third gen since no third gen came with a 12 bolt. The only junkyard diff that will swap is out of another third gen.
The truck 12 bolt is too wide. The truck 12 bolt is also weaker than a car 12 bolt. The pinion shaft is smaller so it needs a truck gear set.
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
