Low/reverse clutch support retainer install
Old Feb 19, 2008 | 06:26 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Got my 700r4 going back together and ran into something I'm not too sure abt. Manual pics are not helping. The piece in question is called the "spring, transmission low and reverse clutch support retainer".
Assuming I have it in right, it looks like the end that engages the clutch support is right on the edge of slipping out of the notch.
See pics..
Do I have this thing installed correctly?
Attached Thumbnails Low/reverse clutch support retainer install-700r4_5.jpg   Low/reverse clutch support retainer install-close_w-support.jpg   Low/reverse clutch support retainer install-w-o_support.jpg
Old Feb 20, 2008 | 12:36 PM
Shagwell's Avatar
Car: projects.......
Re: Low/reverse clutch support retainer install
correct. - its comonly refered to as the "anti-clunk spring".
Old Feb 20, 2008 | 12:45 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Is it supposed to look like it's abt to slip out of the cutout in the clutch support? It's appearance kinda bugs me.
Old Feb 21, 2008 | 01:55 AM
Pro Built Automatics's Avatar
It is correct. If you are using the Beast sunshell, then in picture two I would grind off at an angle about 1/8" for clearance. I am going to put this in the instructions in my build kits in the future.
Old Feb 21, 2008 | 04:42 PM
Shagwell's Avatar
I had one make a funny noise that went away, I realized what it was on the next build....
Old Feb 22, 2008 | 07:03 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
So if I understand this correctly, I need to grind off 1/8" from the curved leg so the grinded surface will be parallel with the clutch support? I've already installed the (beast) sunshell but didn't notice any interference. However, I'm not taking any chances since this will be difficult to get at later.
Thx guys!!
Old Feb 22, 2008 | 08:59 AM
If you did not have any interference, you are ok here.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
red90IROCls1
Aug 25, 2015 06:56 AM
rsrmoore
Aug 7, 2015 08:44 PM
