Transmission Mounts
Old Feb 21, 2008 | 09:57 AM
Artic White's Avatar
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Transmission Mounts
I am having a horrbile time trying to find a poly mount for my 92 camaro with 305 and t5. I have looked everywhere and they all seem to not have a stud coming down from the bushing to secure it to the crossmember with a nut, they have a setup where i'd have to use a bolt.
Where did you get your poly transmission mount?
Old Feb 21, 2008 | 10:03 AM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
Re: Transmission Mounts
i got mine at autozone,its a energy suspensions polyurethane mount and it was only 20 buks,it has all the bolts,spacer and washers included,most are universal and they dont have the stud goin down like the oem mounts are
Old Feb 21, 2008 | 10:11 AM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Thank you for the quick reply. Do you still happen to have the part number? Did they need to order it or was it in stock?
I keep somehow breaking these stock replacement rubber ones and I don't drive the car that hard so I hope poly will help
How well have the poly mounts held up?
Old Feb 21, 2008 | 10:31 AM
lonman89's Avatar
yea they have them in stock,i havent been disappointed yet with it,im goin to upgrade all my bushings/mounts with new poly mounts,IMO i think the poly mounts/bushings are way better than the oem rubber ones
Old Feb 21, 2008 | 10:43 AM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Thanks. I am going to definitely check out my autozone today, Thanks again
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theshackle
Aug 23, 2015 03:49 PM
