Aftermarket clutch fork for 84-92?
Old Feb 21, 2008 | 08:13 PM
A Atwood's Avatar
Does anyone know of a heavy duty after market clutch fork for the stock style 84-92's. I have not been able to find any. Thanks.
Old Feb 21, 2008 | 08:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Aftermarket clutch fork for 84-92?
Never seen one.
Old Feb 21, 2008 | 08:32 PM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
What's wrong with the stock one? Lakewood makes a clutch fork, but I think it's designed for a y-body.
Old Feb 21, 2008 | 09:30 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
if your haveng problems with a stoch clutch fork... then you might have BIGGER problems that just a clutch fork? is it bending?
Old Feb 22, 2008 | 09:37 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yea, its a totally different animal. I have one sitting int he garage....
Old Feb 22, 2008 | 10:10 AM
A Atwood's Avatar
Nothing is wrong with my stock one currently. My car is going through a large transformation right now. So, since I will be using a stronger pressure plate, I figured now would be a good time to put a beefier fork in. But it does not look like there is a choice. Oh well. Hope it holds up. Thanks for the help.
ARN
Old Feb 22, 2008 | 01:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i suppose you could always box the fork.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
