7004R a NO-GO
Old Feb 26, 2008 | 01:41 AM
zrated57's Avatar
700R4 a NO-GO
My 700R4 is acting up. I hear a whining noise when I first start it at idle and in gear. Today, it starting slipping & bucking while crusing at 35mph in 4th gear. Then, it stopped going all together while it was in gear. I could put it in reverse, drive, etc and it wouldn't go anywhere. I checked the transmission and it was very low on fluid. I filled it back up and it shifted into drive and went down the street and then did the same thing again, was in gear, but wouldn't move. I noticed a small amount of tranny fluid on the ground after sitting for a few minutes. I had the governor replaced a week ago and it worked okay, until now.
Does anyone have an suggestions on what the problem with my transmission could be?
Thank you
Oh, and why when I let it sit for awhile and then start it up it will shift into gear and drive a little bit, but then act up again?
Old Feb 26, 2008 | 02:07 PM
zrated57's Avatar
Re: 7004R a NO-GO
The transmission fluid is full and dark in color; and seems to be leaking onto the ground.
Old Feb 26, 2008 | 04:44 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: 7004R a NO-GO
governor cover leaking?
Old Feb 26, 2008 | 07:35 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: 7004R a NO-GO
i'm still trying to figure out why anybody would want to be in 4th at 35mph
Old Feb 27, 2008 | 12:05 AM
zrated57's Avatar
Re: 7004R a NO-GO
The car will move in gear if I rev the engine up really high and it will slowly creep along, but only while the engine and transmission are completely cold. After it has been driven for about a mile it will not continue movig. It will be in gear and I can rev it up without the car moving at all.
Bstrang6
Sep 28, 2016 04:58 PM
Warnd
May 2, 2013 07:40 PM
dsterling@roche
Oct 29, 2010 01:31 PM
drivera
Jan 28, 2007 09:41 AM
Dick1234
Feb 25, 2002 05:42 PM
