Which of these lockup kits are good for the money?
Old Feb 26, 2008 | 09:50 AM
BigBadJohn's Avatar
Looking for a lockup kit for the 700r4 but I dont understand the differences between the kits. Some say you dont need to drop the pan others say you have to. Which is best, drop the pan or dont drop the pan and why
heres the kits im looking at
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=016
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=009
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=007
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=008
Old Feb 26, 2008 | 10:54 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Re: Which of these lockup kits are good for the money?
The reason you wouldn't have to drop the pan is that their pressure switch installs in the external 4th gear pressure port as opposed to the port on the valve body, where the stock switch is located. Why do you need this kit? Your car should be computer controlled (unless it's something different than in your profile). Are you going carb?
Old Feb 26, 2008 | 11:48 AM
BigBadJohn's Avatar
Originally Posted by TA In Progress
Are you going carb?
Im thinking about it
Is there an advantage of one over the other or of durability?
Old Feb 26, 2008 | 03:39 PM
jean's Avatar
Hi , don't worry you're not the only one lost. So far here is what I found the more easy to undertsand. In my opinion if you have still the lock-up wiring in your trans use it and don't get any kit ... If this is what I undestood ...
http://www.700r4.com/tech/tcc/
http://www.700r4.com/tech/tcc/brake_.../diagram.shtml
Old Feb 26, 2008 | 08:28 PM
Axle/Gears: 3.27 BW
I would recommend a kit that has a brake switch so when you hit the brakes the converter will unlock when the brakes are applied. Otherwise your car could stall when you hit the brakes because of the converter being locked.
Old Feb 27, 2008 | 12:23 AM
BigBadJohn's Avatar
Which of the above kits I listed include the brake switch?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
TreDeClaw
Aug 14, 2015 06:58 PM
