tranny and limited slip
Old Mar 2, 2008 | 07:48 AM
liteumup387's Avatar
Car: 1982
Transmission: 350
i have an 82 camaro and i was just courious on how to tell the difference between the turbo 350 trans and the 200c trans i thought i had the turbo350 but then i found out that the 200c is the same size so im lost lol and how s h i t t y is the 200c
does anyone know a place that sells the stock limited slip units because i cant get this one tire fire to hook up lol
thanks,
john
Old Mar 2, 2008 | 09:05 AM
Re: tranny and limited slip
http://www.bulkpart.com/Merchant2/me...General-Motors
No...
You don't want that garbage anyway.
A quick, cheap, and dirty way to get posi into your car, is to find the stock rear out of a LS1 car (98-02 Camaro/Firebird V8); and get a set of these axles right here. Keep in mind that if your car has a 2.73, 2.93, or 3.08 gear, this won't work; it has to have 3.23 or higher. If you have those other crap gears, you'd do better to just swap a whole LS1 rear into your car and forget about the 82 stuff altogether. Only thing with that is, then you'd need 4th gen wheels because the 4th gen rear is longer and requires different wheel backspacing as a result; and you'll have to do a bit of minor fab work of some kind to hook up your car's SAE brake lines to the 84-up metric ones on that kind of rear.
Ed1LE
Sep 30, 2018 09:14 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
