Difference Between Street/Strip & Pro Street?
Old Mar 3, 2008 | 01:30 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I have a high horsepower street car and I want to keep it that way but have the transmission to back it up. ProBuilt has two different setups.
Street / Strip
and
Pro Street
Obviously I can see the hardware difference but will the pro-street still be street friendly? As in my driveability will not be affected if I go with the Pro Street? Thanks.
Old Mar 3, 2008 | 06:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Difference Between Street/Strip & Pro Street?
Pro Street is probably set up with different tolerances. Not designed for high mileage and should be rebuilt every few years.
Old Mar 3, 2008 | 07:08 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Ok, so for someone who puts miles on their car, the Street/Strip setup is probably better? I put maybe 6-9K miles on it every summer.
Old Mar 4, 2008 | 04:49 AM
Pro Built Automatics's Avatar
The main differences in the Pro Street is the additional clutch to the 3-4 pack (9 total), and the use of the HD steel sleeve in the input drum to keep it from breaking open. It does not shift any harder at part throttle, just added clutch capacity and durability.
Old Mar 4, 2008 | 08:51 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Thanks.
And if I already have a TransGo shift kit, I probably don't need the transgo seperator plate from the rebuild kit, correct?
Old Mar 4, 2008 | 10:38 PM
Which Shift kit do you have?
Old Mar 4, 2008 | 10:44 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I don't have a model number since it was awhile ago. It is a TransGo Shift kit.
Orr89RocZ
Feb 13, 2016 10:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
LT1Formula
Aug 20, 2015 09:36 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
