6 cylinder torque converter
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Whats the stock stall for the 6 cylinder torque converter for a 1991 firebird. The main question I have is how would it work on a v8? Its not from the 60 degree V-6 patern 700r4 either.
Here are photos of the transmission.
[IMG]
[/IMG]
[IMG]
[/IMG] Last edited by shaggy56; Mar 7, 2008 at 05:51 PM.
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: 6 cylinder torque converter
What it stalls behind a v-6 is irrelevant. If you put it behind a v-8 it will stall higher(how much?dont know that). I once use a stock converter for a 4-cyl vega in a th350 behind a 355 with a b&m 177 blower on it, gave me about 3250 of stall. It wont live long though.
Car: 71 Nova
Exactly why wouldnt it live long? If im not drag racing with it what exactly will go wrong?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I have successfully used Buick V6 torque converters behind Buick and Olds V8s with no problems. With a small block they give me about 1800-2000 and with a big block I get around 2200. Nothing to brag about, more like a "saturday night special" type of thing. It's better than stock to the point that you're happy you did it.
If you are using a 4.3 converter you may not notice much of a difference. I'm betting you'll be in the 2000 range as well.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
