rebuildable posi?
Old Mar 8, 2008 | 08:58 AM
racer rick's Avatar
Car: 68 firebird,84 ta,84 short box,
Engine: 350,305,350
Transmission: t10,700,350
Axle/Gears: 323,410
rebuildable posi?
is the stock posi rebuildable,were do you find parts.mine looks like it has been well abused.
Old Mar 8, 2008 | 10:05 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: rebuildable posi?
Nope.
Old Mar 9, 2008 | 07:01 AM
scout1069's Avatar
Car: 1986 IROC Z28
Axle/Gears: 3:23
why are they not rebuildable?
Old Mar 9, 2008 | 08:14 AM
Pat Hall's Avatar
Because the Auburn design licks *****, and uses non-replaceable, cone style clutches. The only rebuildable posi is the Eaton, clutch style unit, which doesn't come in our cars stock, and costs a pretty penny to buy aftermarket.
Old Mar 9, 2008 | 11:31 AM
scout1069's Avatar
Car: 1986 IROC Z28
Axle/Gears: 3:23
So what are the signs of one going bad?
Old Mar 9, 2008 | 12:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Single tire fryer.
Old Mar 9, 2008 | 09:58 PM
Pat Hall's Avatar
Yeah, that's definitely the most obvious indication! You can also jack up the rear to where just one wheel is off the ground and see how hard it is to get it to slip and start turning. If it takes a good amount of effort to get it to slip, your clutches are still holding pretty good, if it slips quite easily, your posi is about done. There's actually specs, and you can use a torque wrench to measure how many ft. lbs. it takes to get it to slip.
dbrochard
Jan 28, 2016 08:42 AM
NZKnight
Oct 15, 2015 02:47 PM
6998poncho
Sep 25, 2015 02:56 PM
Prodigious
Sep 18, 2015 05:23 AM
manifoldsrme
Sep 17, 2015 11:40 PM
