please help super t10 ratio x rear gear ratio
Old Mar 9, 2008 | 12:20 AM
raidercelticfan's Avatar
hi, i have a 70 camaro with a 454 and a 1981 super t10, the t10 has a 3.42 first gear,2.88 second gear,1.46 third,1.00 forth,(1st gear sucks) i just got my taxes and i want 2 get my trans rebuilt with a new gear ratio and rear end gears built 2 match, i wont be racing but i want it 2 jump when i get on it, i also drive on the freeway so i need a combo that wont tack out when im on the freeway, any help or info will be appreciated, thanks darren
Old Mar 9, 2008 | 12:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: please help super t10 ratio x rear gear ratio
What's wrong with the current ratios?
What are the available choices anyway? Might want to contact a company that makes the gears. Tremec is a good start, to see what's available.
Also, this is a third gen forum, not first or second so....
Old Mar 9, 2008 | 01:33 AM
my combo now sucks!! i have no first gear my rpms shoot shy high in 30 feet my second gear aint much better third and forth are ok,st10's have 5 set up's heres what i have 2 chose from 2.43-1.61-1.23-100 2.64-1.75-1.34-100 2.64-1.60-1.23-1.00 2.88-1.91-1.33-100 i have no idea what works with what, i just know what i have sucks, im not looking 4 build a race car i just want a correct combo that jumps in town and can still cruise at 70 with around 3000 rpms
Old Mar 9, 2008 | 08:18 AM
Pat Hall's Avatar
Use the calculator in this link. You can plug in any ratio you want and it'll give you the answers you're looking for. http://www.5speedtransmissions.com/startlineratio.html For what it's worth, if you went with the 2.64 first gear in the trans, and a rearend gear around 3.55 to 3.73, you'd have a great launch. 3.42 is way too low for 1st gear in the trans unless you're running 2.73's in the rear, or have a 6 cylinder engine.
Old Mar 9, 2008 | 04:38 PM
thanks 4 the help, i just used the calculator on the site and i think im going 2 go with the 2.88 first with around 3.50 rear gears, it has a 10.08 final and 2200 rpm at 75, thanks again 4 the help darren
Old Mar 9, 2008 | 05:24 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
why not change the rear end gears? you could do a 3.08 with that t-10 and have great acceleration.
Old Mar 9, 2008 | 06:18 PM
the 3.42 first and 2.88 second are 2 low my first gear is only about 25-30 feet, i have 2 shift 2 fast, i think it will be the same with 3.08s thanks darren
Old Mar 9, 2008 | 06:56 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i have a 2.88 1st. and 3.23 in the rear, that seems fine to me.
Old Mar 9, 2008 | 07:33 PM
hi, how are your rpm's at 75mph with the 2.88 first and the 3.23 rear, i ran that combo on the calculator it was around a 9.30 high range and 2000 rpm at 75 just wondering how close the calculator is, thanks
Old Mar 9, 2008 | 08:02 PM
its more like 2200-2500ish. i have a nice tach but my speedo is not too acurate?
Old Mar 9, 2008 | 08:05 PM
thats just what im looking 4 any thing over 3 is to much on the freeway 4 me, i think i might go with the 2.88 and 3.23 THANK YOU
Old Mar 9, 2008 | 08:14 PM
. with that combo, you kinda get to play with both ends of the spectra! IMO?
your a raiders fan?
Last edited by vasquezmrysvll; Mar 9, 2008 at 08:15 PM. Reason: Automerged Doublepost
Old Mar 9, 2008 | 08:19 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
you will like your current trans ratio's with the 3.08's better. meaning lower rpm highway and great acceleration. do the math.
Old Mar 9, 2008 | 11:50 PM
hi, the math looks good 10.53 high range,but i searched gear ratio calculator and they show the power band of all the gears its not even like all the other st's it has a major rpm drop off unlike the other 4 i think 2 be safe im ah have 2 spend the money and gear the car correct, thank you 4 the input
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
beachrodder
Aug 7, 2015 04:27 PM
