rear end problem
Old Mar 12, 2008 | 09:27 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
rear end problem
i just bought a 3:73 gear posi rear end and its only a lil over a yr old.only some times i can get both to spin for a smoke show.most of the time 1 spins.could it be i need to do a rear end fluid change.
Old Mar 13, 2008 | 06:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end problem
Did you change the fluid/limited slip additive when you purchased the rear?
JamesC
Old Mar 13, 2008 | 07:02 AM
Sounds like it's not a posi NOW, even if it was when it was new. More likely though it doesn't have posi at all.
What kind of "posi" is it? How do you know it's a posi? What fluid did you put in it when you installed it in your car?
Old Mar 13, 2008 | 07:05 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
JamesC
the limited slip additive is a must . change fluid and don't forget the additive . good time for a visual inspection of rear end .
Old Mar 13, 2008 | 02:39 PM
Car: 86' Z28 Camaro
its a posii and i havnt changed the fluid yet like i wrote..i was wonderin if not changin the fluid yet wold casue this n changin it would fix it. it posi it works wen it wants to.i had a non posi before i kno how it works
Old Mar 13, 2008 | 04:04 PM
What the additive does, is let the clutches slip smoothly, when the 2 wheels both have traction and need to turn at different speeds, like going around corners. Lack of additive will make the clutches groan and chatter going around corners. That will not make it slip.
Sounds like, if in fact it's really got the parts in it and you've seen them with your own eyes and this isn't just a "I know it is because it makes 2 stripes" posi or a "the RPO codes said it is" posi, it's just worn out. Time for a new one.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
