Want some opinions
Old Mar 13, 2008 | 08:03 PM
redline24's Avatar
Want some opinions
I just bought a 91 rs with the 305 and automatic. The car came with a borg warner 9 bolt that I can swap into the car but the thing I dont like about it is that it only has 2.77 gears. The stock rear howles a little. Would you guys swap for the 9 bolt and 2.77 or sell it.
Old Mar 13, 2008 | 09:30 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Re: Want some opinions
most likely your current 10 bolt has a 2.73 anyway. Does the BW have the same brake setup?
Old Mar 14, 2008 | 08:10 AM
redline24's Avatar
The bw has disk brakes. I would like to have 3.42 or 3.73 or something around that.
Old Mar 14, 2008 | 08:52 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
There are more aftermarket options for the 10 bolt. If your current rear is drum and the BW is disc then you'll have to do some work to convert the brakes. If you want to go up to a 3.42 or 3.73 (3.45 & 3.77 in the BW, i think), then either way you'll need to rebuild the rear.
I would sell the BW and use the money towards rebuilding the 10 bolt.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
