From 0-20 Makes a Chirping/Squeeling noise
92 RS 305
160K
Recently Changed Timing, Plugs, Wires, Distributor Cap/Rotor
I believe the problem to be my transmission. When the car is in drive the tranny will make kind of a squeeling/chirp. Also, when I put the pedal to the floor and kick into O/D, I can feel something slam down. I believe it may be the tranny. Do I need new tranny mounts? What commonly would cause this?
The transmission shifts okay, the noise is just noticeable at low speeds. It's also not consistent, it only happens sometimes.
160K
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
Re: From 0-20 Makes a Chirping/Squeeling noise
if noise is not there when in park but is there in gear probablly torque converter. for the slamming check trans mount and torque arm mount.
Engine: 4++,350 & 305 CIs
Trans mount and dry U joints.
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 11, 2015 10:11 PM
