TV Cable Adjustment Problem
Old Mar 29, 2008 | 07:54 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am having problems adjusting my TV cable. The problem is that after I push the button in and slide the cable all the way back to the firewall and set the cable by pulling throttle to WOT, the black part that has the grooves cut into it comes all the way out before I get to WOT. What should I do to fix this?
Old Mar 29, 2008 | 11:30 AM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: TV Cable Adjustment Problem
you need a partner to hold the throttle for you or hold down the gas petal .
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
db057
Sep 4, 2015 07:57 AM
