700r4 loses all gears
Old Mar 30, 2008 | 06:54 PM
1989iroc66's Avatar
I have an artcarr performance trans (seems to be from a corvette) that is supposidly new (ebay) and installed in my 89 iroc. The trans goes into forward rev neutral fine but after driving about 300 yards i loose everything untile i shut off the engine let it sit for a min or so then it has all gears again then loses them again and so on and so forth any advise would be helpfull
Old Mar 30, 2008 | 07:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: 700r4 loses all gears
did u put fluid in it? sounds like its overheating super-quick.
Old Mar 30, 2008 | 07:11 PM
1989iroc66's Avatar
a new filter and fluid are in the trans. engine ran for at most 5 min when this happened
Old Mar 30, 2008 | 07:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
What do you have for a cooler?
Old Mar 30, 2008 | 07:43 PM
1989iroc66's Avatar
stock cooler
Old Mar 30, 2008 | 08:42 PM
1989iroc66's Avatar
i understand where u are going but i dont understand how the trany heated up that quickly
Old Apr 2, 2008 | 01:46 AM
ParkerTPIz's Avatar
does it make any weird sounds or noises? did u put it in? did u make sure everything was fastened tightly and that you put trans fluid in the torque converter, and did u make sure the torque converter was installed properly?
just ideas...
Old Apr 3, 2008 | 11:13 AM
wolfspirit187's Avatar
Car: 1988 trans am GTA
Engine: 350 V8 tpi roller motor
Transmission: 700-R4
Axle/Gears: 3.73 b/w posi will change out soon
I think I know what is wrong with your Trans who ever you bought it from cooked it (overheated it big time ) so when the temps get up inside of it the clutches slpig big time and probley the planetry gear are also shot does it wine after a few seconds and also when it is not working after the 300 yards you can throws it in any gear but park and nothing happens if you it was likei said cooked ( happened to my friend with the car i got now ) what it is the person who had it before you ran it way to long low i mean LOW on trans fluid as in almsot none on stick you need it rebuilt sorry
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
