I NEED INFO BAD BEFORE I HAVE SERIOUS PROBS
Old Mar 31, 2008 | 01:57 AM
styxxx74@verizo's Avatar
Car: 1987 iroc-z
Engine: 305 tpi
Transmission: tci
Axle/Gears: 2:73
I JUST GOT AN 87 IROC 305 TPI FROM A FRIEND,THE CAR HAD MODS DONE BEFORE HE GOT IT SUCH AS SLP RUNNERS HOLLEY 58MM THROTTLE BODY MSD IGNITION ACCELL 10.5 MM WIRES, BORLA STAINLESS EXAUST,SATURDAY NIGHT SPECIAL CAM (NOT SURE OF DURATION OR LIFT? 1.8 CRANE ROCKER ARMS,B&M MEGASHIFTER AND POSSIBLY A CHIP(I HAVEN'T CHECKED YET WITH ALL THE MODS THE PREVIOUS OWNER WOULD HAVE TO BE A TOTAL DOPE.I LISTED THESE JUST TO LET EVERYONE KNOW A LITTLE ABOUT THE CAR BEFORE I ASK THIS FIRST QUESTION. I THINK THERE COULD BE AN ADJUSTMENT PROB WITH MY TRANS,IT WILL NOT SHIFT OUT UNTIL IT REACHES 4000 OR BETTER RPM.WEATHER I SHIFT IT MANUALLY OR IF I LEAVE IT IN DRIVE AND WHEN IT DOES SHIFT IT PUTS YOU WRIGHT IN YOUR SEAT.THE TRANS FEELS FINE WHEN IT DOES SHIFT NO NOISES OR ANYTHING IT JUST WON'T SHIFT OUT BEFORE 4000RPM.SORRY ABOUT THE LONG PARAGRAPH BUT I FIGURED THE MORE INFO THE BETTER.ANY SUGESTIONS WOULD HELP. P.S I THINK IT HAS A 2800-3000 RPM STALL IN IT.
Old Mar 31, 2008 | 09:50 AM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: I NEED INFO BAD BEFORE I HAVE SERIOUS PROBS
You could try adjusting the T.V. cable but I doubt that is the source of your problem. My friends camaro did the same thing last year. It wouldn't shift out of first till 4500 when the car was cold. Once it warmed up the issue wouldn't be as bad. We replaced the converter and that solved the problem. Also please remember to diactivate the capslock when typing
Old Mar 31, 2008 | 10:46 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
With a high stall it should still move.You might want to check if you have enough fluid in the tranny sounds like that might be the problem.
Old Mar 31, 2008 | 03:25 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Old Mar 31, 2008 | 05:58 PM
Car: 1987 iroc-z
Engine: 305 tpi
Transmission: tci
Axle/Gears: 2:73
sorry about the caps i'm new to the message board thing. thanks for the info i'll give the tv cable a shot. and you are wright when the car warms up it does get a little better. i think i'm just going to go ahead and change the trans filter and fluid too the car has been sitting for a while. do you know anything about tci tranny's?do they recommend a certain type of trans fluid and filter.
sorry about the caps i didn't know. my bad
Last edited by styxxx74@verizo; Mar 31, 2008 at 05:59 PM. Reason: Automerged Doublepost
Old Mar 31, 2008 | 06:05 PM
Car: 1987 iroc-z
Engine: 305 tpi
Transmission: tci
Axle/Gears: 2:73
the car does move. the prob is when i take off in 1st and lets say i let the car rev to 3500 and then i let off and get back into the throttle slow the car revs like it's in neutral until it gets to between 2800-3000 rpms then it takes wright off without any grinding banging or any type of noise. i got the car with this trans already in it.the way it is doing this is what makes me thing its got a stall in it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Blue419
Sep 10, 2015 01:03 PM
Billy Decker
Sep 4, 2015 03:46 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
