which rear end
Old Apr 3, 2008 | 05:20 PM
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
which rear end
i just got my 89 iroc with a 383 stroker back from the dyno shop but it blew 3rd and 4th gear. it has a 700 r4 trans with the stock rear end for now. its putting out about 375 hp to the wheels. what is a good trans setup to put in it that isn't too expensive??????
Old Apr 3, 2008 | 05:44 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: which rear end
try a search
Old Apr 3, 2008 | 07:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: which rear end
Good that's not expensive? Powerglide or TH350.
Building a high HP engine means building the entire driveline to handle the power. Don't expect anything stock to survive much above factory HP levels if abused. Your differential may or may not survive. Your only options are to run it until it breaks or spend $2500+ for a 9" or 12 bolt designed for third gens.
As for the transmission, it depends what you want to do with it. Do you want strictly performance? Do you want an OD gear? A TH400 will take about anything you can throw at it but it's a little more difficult swap. A 4L80E is even better with an OD gear but because it needs a computer to operate, it can be a $3000+ swap. It also weighs more than twice the weight of a simple 2 speed powerglide.
Old Apr 4, 2008 | 11:07 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: which rear end
I have the 700r4 with a pro built rebuilt kit in that can handle 650 ponies. So far no problems. The kit only cost 500 bucks. Talk to Dana at pro built he will hook you up. For the rear end I would go with a Strange 12 bolt, at Spohn they only cost 1927. I am putting one in my car in about a week or so. All said you can do both for under 3 grand. Just my
Old Apr 4, 2008 | 04:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: which rear end
you cant buy the strange 12 bolt for that unless you just want a spool. Add 550bux to that for a posi, then more for other upgrades.
Old Apr 5, 2008 | 12:06 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: which rear end
Yeah I know, If you want a spool it cost 1927, with an eaton posi your loosing around 2500
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
