re-usable diff cover gasket?
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
does anybody make a re-usable diff cover gasket for the stock GM 10-bolt? i have a paper gasket on there now with no problems but i heard about re-usable rubber gaskets. i tried searching online and couldn't find anything.
Car: Pair of 92 Z28s
Re: re-usable diff cover gasket?
Ive always just used a bead of high temp rtv and never had a problem.
I think you can still get the gasket from the parts store or dealer though.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
RTV red (orange) high temp silicone. I haven't used a gasket on a diff since the early 80's.
If you want something even better, use this
http://www.permatex.com/products/Aut...sket_Maker.htm
This stuff is designed to work in an oily environment. I use it as end rail gaskets on my intake manifold. The only downside is how well it sticks. You need a razor blade or buffing pad to remove it. It's commonly used on many factory engines as a replacement for gaskets. Guaranteed not to leak.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
rudolphschenker
Sep 4, 2015 02:41 AM
