canadian 700r4
canadian 700r4
i have a canadian model 85 trans am with a 700r4, and it is a canada model it has no ecm so it has a vacuum operated lock-up converter, i recently put a edelbrock carb and intake on, and i don't know where i should hook up the TCC vacume, i tried using a port on the carb and the converter does not lock up, do i need manifold vacuum for it?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: canadian 700r4
Never heard of a vacuum lockup converter but there may be one. Normally when a transmission needs a vacuum source such as the modulator on a TH350, it needs manifold vacuum. A carb can have venturi and/or manifold vacuum ports on it. Manifold vacuum is the lowest port available.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
