how do you bleed clutch master cylinder?
Old Apr 8, 2008 | 05:47 PM
tripingeorge3's Avatar
Old Apr 8, 2008 | 06:09 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: how do you bleed clutch master cylinder?
There is a bleeder on the slave cylinder or you can use a mighty vac.
Old Apr 13, 2008 | 01:22 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
If I remember correctly the bleeder valve is kind of hard to see and get to. It's up on top in the front of the cylinder. We ran it up on the ramp and I had to kind of put my finger on top of it when loose and "feel" for the air bubbles coming out. Real pain in the butt.
Old Apr 13, 2008 | 08:55 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Well you would be able to see the bubbles if you used a length of hose and ran it into a bucket. Make sure you are depressing the pedal while you close the valve simultaneously. It can be a 2 or even 3 person job one to keep the reservoir full, one to pump the pedal and one to close the valve, or one if you have a bleeder friends are the best tools you can have.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
