gooey mess inside rear drum??
Old Apr 9, 2008 | 12:41 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
my car is a 1989 camaro RS with a 305 tbi, mileage is 165K. i rotated my tires because im getting a strange noise out of the suspension at lower speeds. i removed the rear tire, i noticed the rear driver side drum was covered in a greasy substance. i removed the drum and the inside was covered in grease. i think its time for a new rear bearing and a new seal. how difficult is replacement? i have never had a rear axle apart on any of the vehicles i have owned and i was wondering what im getting into. im setting millage records with the camaro, i have never owned a vehicle this high in millage. this car is still in fantastic shape (no winters) so im happy to continue to fix what ever it needs.
Old Apr 9, 2008 | 02:57 PM
zee28's Avatar
Car: 86 iroc
Re: gooey mess inside rear drum??
its grease or just dirty fluid?if its not a leaky wheel cylinder then yea your right about the rear.I would leave rebuilding it to someone who knows what they are doing,but thats me.Mine went out and I just got a good used one from the j yard and replaced it if you go this route check it out good and get the gear you need or want.good luck
Old Apr 9, 2008 | 05:10 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
alxe seals r a piece of cake. the wheel bears r a lil more involed
Old Apr 9, 2008 | 11:28 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
i know its not a wheel cylinder. i replaced both last summer, and the fluid is much too thick to be brake fluid. it has to be axle seals. i was thinking about replacing the bearing as well. how much more work is it to replace the bearing?
jaridjohn
Jul 8, 2024 03:49 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
z28addict8490
Aug 7, 2015 08:48 PM
