So i broke
Old Apr 10, 2008 | 10:56 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
So i broke
My speedo and odometer doing a burnout the other day. Anyone have a good sticky that i havent found on how to fix it? I also installed different gears on my car so is there another sticky for calibrating it?
Old Apr 11, 2008 | 02:11 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: So i broke
well the odo probably isn't working because the speedo isn't working. First check the speedo cable for binds or kinks, then that it is properly connected to the tranny and to the gauge cluster.
As for what speedo gears you need check the sticky in this board called "t-5 drive and driven gears" It has info about what ratio and what gears to calibrate your speedo.
Old Apr 11, 2008 | 05:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: So i broke
And if the above seems good, remove the cable from its housing. It's possible the cable has snapped. If the odometer is truly broken, check the following link:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
