T56 Vs. TKO
Old Apr 13, 2008 | 09:01 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
T56 Vs. TKO
I really do not know much about either trans I just know that I need one.
Please help me weigh the decision!
Old Apr 13, 2008 | 09:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: T56 Vs. TKO
t56 is a 6 speed
tko is a 5 speed
the t56 can be found used for a bit less than a new TKO
the tko needs a different trans yoke
the t56 has 2 OD gears
the TKO is stronger than a stock t56, but you can beef the t56
i think the tko is lighter
other than that they both need the same parts
i have the tko600, and i love it, though i have nothing against having a t56
Old Apr 14, 2008 | 08:05 AM
mxcrazed's Avatar
Engine: None
Transmission: none
Re: T56 Vs. TKO
Could somebody please elaborate on the installation. What am parts are required and how does it works out dollars and cents?
Old Apr 14, 2008 | 04:26 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: T56 Vs. TKO
there is a tech article about the t56 swap and parts list and price list.
there are going to be modifications needed for both setups.
I'm currious if you've considered astroperformance for a gear cluster swap.
https://www.thirdgen.org/forums/astr...per-t-5-a.html
I have no experience with this kit and am not endorsing it, it just seems like a good alternative if you want an easy installation.
Old Apr 14, 2008 | 04:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: T56 Vs. TKO
forget upgrading the t5 its not worth it. The gears will not help
Old Apr 15, 2008 | 09:26 AM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: T56 Vs. TKO
I just picked up a complete T56 swap from a wrecked 96 Z28 for 900 bucks with only 60k on it. Thats on the cheap end as far as prices go.
Old Apr 15, 2008 | 06:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: T56 Vs. TKO
you did very very well, good find
Old Apr 16, 2008 | 09:19 AM
WIll36's Avatar
Engine: 355, 408
Re: T56 Vs. TKO
Yeah, its amazing what you can find surfing craigslist late at night when your bored
Old Apr 17, 2008 | 07:22 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Re: T56 Vs. TKO
I got my t5 for $100 on craigslist thy guy also had a 700r4 for $100 and a "rebuilt" 86 LB9 for $200
Old Apr 17, 2008 | 11:28 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Re: T56 Vs. TKO
tell me about it! over half the stuff i personally put in my car is from craigslist! im gonna call it....the craigslist car. but anywhoo. i think a t56 is a nice swap and upgrade. 6 gears seems hella fun also.
Old Apr 18, 2008 | 01:17 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: T56 Vs. TKO
6 speeds is fun, if mxcrazed goes that route though he'll need to change his rear end gears also though. Believe me I had a 9 bolt 2.77 with the M29 t56 and I never even touched 6th. the 4.11's are perfect though, I just did a 6 hour trip 2 days ago cruising at 100mph at 2500rpm and got around 24mpg
Old Apr 18, 2008 | 11:30 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Re: T56 Vs. TKO
I heard that 4.11 is to numerically high for the small pinion of my 10 bolt is that true?
Old Apr 19, 2008 | 01:28 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: T56 Vs. TKO
no. Mine is a ten bolt. Just with your 2.73 rear if you wanted to go to a lower gear 3.23 and up will need a 3 series carrier, or you can get aftermarket thick gears that can work on a 2 series carrier.
It is of course much easier to find a rear end with the gears and posi you want already complete..
Old Apr 19, 2008 | 08:15 AM
mxcrazed's Avatar
Engine: None
Transmission: none
Re: T56 Vs. TKO
the answer is an ls1 rear end now i need to look at ls1 wheels
Old Apr 19, 2008 | 09:18 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: T56 Vs. TKO
you don't need a LS1 rear, all 82-02 F-body 10 bolts are the same with some slight internal differences, namely in 88 they switched to a stronger 28 spline axles. Also different brakes through the years also. 88 and older got iron calipers that are junk, 89-97 fot 11.65" PBR aluminum calipers (more desirable), and 98-02 got 12" disks with massive aluminum calipers (the best).
You don't have to upgrade your rear end if do decide to go t56, just a forewarning that it's not much fun with 6 speeds and 2 series gears.
also 4th gen rears are longer forgot to mention that.
Old Apr 19, 2008 | 11:16 AM
WIll36's Avatar
Engine: 355, 408
Re: T56 Vs. TKO
Well if I remember correctly from another thread he blew up a T5 not that long ago, so I would say the logical steps are for him to first get his hands on a T56(my preference of a TKO) then do an LS1 rear because I like the way they sit in the cars. By the way I have a spare one that I would be willing to sell now that I'll thinning out my supply of extra parts. Then do 17x11s in the rear.
Old May 27, 2008 | 10:57 PM
jtyson8602's Avatar
Car: LB7 Duramax CCSB 4x4
Engine: 6.6L Turbo Diesel
Transmission: 5 spd Allison
Axle/Gears: 3.73s
Re: T56 Vs. TKO
i have the adjustable torque arm with cross member attachment, driveshaft with yoke and bell housing adaptor for the tko set up.All spohn with about 14k on them. and it was used behind a stock block so not much stress on anything. I have the trans too but Im not selling that one. I do suggest the tko though if youre going for big power eventually. they are built stronger and can be built to hold more than any t56. But if youre into a lot of highway cruising, the 6 spd may be better. if you want the parts call me 505 379 1917. I dont check the threads often so thats why you can have my number. Good luck!
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
