Ford 9 noob questions
Old Apr 15, 2008 | 11:16 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Finally got my third member today. I'm putting a 1350 moser yoke on it. It came with a large washer or a sleeve. I'm not sure if this is supposed to go between the yoke and bearing or under the nut?
Also, what should I torque the nut too?
Anything I should look at while I have the member out? Its a c7aw case and the pinion support appears to be the daytona with the raised bolt support area. The wear on the ring gear looks great. Nice and even and in the center.
Old Apr 15, 2008 | 02:12 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: Ford 9 noob questions
Ok apparently its a spacer for the yoke.....
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
armybyrd
Aug 28, 2015 03:38 PM
InfinityShade
Aug 22, 2015 08:00 PM
redmaroz
Aug 16, 2015 11:40 PM
