What kind of a stall am I looking at here?
Old Apr 15, 2008 | 11:20 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ALright, I have a 383 fully forged lower end.
Dart pro1 200cc heads 64cc chambers
holey stealth dual plane intake
750cfm speed demon carb
nitrous roller cam http://store.summitracing.com/partde...8&autoview=sku
full roller lifters and 1.6 rockers
A 150 wet shot probably feeling like a 200 shot with the cam.
I will be also getting a performabuilt transmission to handle the power.
I just wanted to see what yall thought I should go with before I talk to them.. It will be a street car, but I dont do too much driving.
Old Apr 16, 2008 | 08:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What kind of a stall am I looking at here?
3000-3500 stall speed based on the camshaft profile. If it was track only, I'd recommend 3500-4000.
I don't think you'll have enough carb for that engine.
Old Apr 16, 2008 | 03:30 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Well I do have bigger jets on the carb, dont know if that helps or not. I am kind of a beginner with carbs. So a 3500 stall would be best? I think that will give me some street rather than none.
Old Apr 16, 2008 | 07:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
That's a big duration cam which requires a lot more stall. Comp cams recommends 2500+ stall converter so 3000 should be fine with nothing less than 2800. The cam will also want a deeper gear in the diff. Don't forget about a big tranny oil cooler to remove the excess heat created by a high stall converter.
Jets sizes don't mean much. Regardless of carb size, you're jetting for a good air fuel ratio. 14.7:1 while cruising and around 12:1 at WOT. The higher reving engine would probably perform better with an 800 or 850 carb. I ran a Speed Demon 850 DP on my old 383.
Old Apr 16, 2008 | 08:23 PM
EvilCartman's Avatar
Car: '82 Z28
Eh, I think the 750 should be ok. Tried an 850 mighty demon on mine and it ran like absolute crap even after a month or two of messing with it. Here's the cam I'm running COMP Cams 12-224-4 with a 4,000 stall converter.
Old Apr 17, 2008 | 12:57 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
YA i talked to the guy from performabuilt and he gives me a tranny cooler. He also recomended a 3500 stall if i dont drive it all over everyday. Which I dont.
Just work school and fun
Old Apr 17, 2008 | 01:03 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
tick....tick....tick....tick....tick.....thats your 9bolt getting ready to blow lol.... 750 will be fine if u know how to tune it right.......
Old Apr 17, 2008 | 02:10 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Lmao well look. I got no more money right now. I will baby it until now. Um how much can a 12 bolt be had for? ANy junkyard rear ends that would help for now?
Old Apr 17, 2008 | 07:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
No junkyard diffs will fit because the third gen uses a torque arm suspension. There's no easy/cheap way to attach the torque arm to any other diff.
A complete aftermarket bolt in 12 bolt is around $2500. You can get a complete bolt in 9" for about the same price but can also build one cheaper by buying the housing/axle package for around $1000 and adding your own third member which can be picked up at a swap meet or junkyard and your own brakes.
Old Apr 17, 2008 | 09:50 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Just to toss in my $.02...with my current combo (check sig), I think a smaller diameter torque converter might be a benefit by reducing the weight of the rotating mass, but as far as more stall than stock, I liked the stock converter better. The higher stall speed, which is designed to "crutch" the lack of low end torque, must be for really over-cammed-for-the-street motors, or strip dedicated cars. I'm still running a LTR TPI set-up, and low-end torque is not something I have to drive the car(by using a high-stall converter) in a special manner to experience. I've still got more low-end than is usable, at least on street tires. Spins hard mid-second gear ...(not that that ain't fun.......!) with a 2600 stall. -Bill
Old Apr 18, 2008 | 01:50 AM
leecar83's Avatar
Car: 91 Camaro
Engine: 355
Transmission: Th700R4
I running a slightly smaller cam with a 3600 stallin my DD. Its much more streetable than I ever would have imagined, I'm considering a restall to 4000 I'd go with a 4000.
Old Apr 18, 2008 | 03:59 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Lmao well I think a 3500 will suffice.
Gunner242
Dec 25, 2015 04:49 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
