trans problem or not?
Old Apr 18, 2008 | 11:04 PM
tank12983's Avatar
Car: bandit II Firebird
Engine: 3.1
Transmission: auto
I have a 90 firebird 3.1L v6 and the problem (or not) is that it revs up to about 6500 rpms before it shift and as a result is feel like it has no power. aslo it deosn't like to shift out of 1st and 2nd on the fly.so is this normal?
Old Apr 19, 2008 | 12:27 PM
performabuilt's Avatar
Re: trans problem or not?
Sounds like you have a tv cable or valve issue, I would check that TV cable is hooked up first
Old Apr 19, 2008 | 01:41 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Almost sounds like the plastic gear sheared off the governor. There is a round metal cover on the left (driver) side of the transmission. Carefully pry it off and pull out the govenor. There is a gear on there held on with a roll pin, if it's trashed get a new one from GM.
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
