T56 swap (gave up on searching)
Old Apr 18, 2008 | 11:08 PM
jupetto's Avatar
I have a 383 T/A. the engine block is an 010 block. I am going to use 3rd gen pedals and I am going to make a shifter plate at work. what else do I need for this swap??? what slave cylinder and resvoir do I use?3rd or 4th gen?? it looks as though there is a diff between LT1 T56's and LS1 T56's so I have no idea which I need to get. I will be getting a spohn cross member for this mod so that will be a simple swap.
Old Apr 18, 2008 | 11:40 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: T56 swap (gave up on searching)
Use the 4th gen slave and reservoir, and it will be much simpler if you use the lt1 t56. I believe you also need a new flywheel designated for one piece main seals as well.
Cheers!!
Old Apr 18, 2008 | 11:59 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Second link for "T56 swap" on google.
http://www.skulte.com/T56.html
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
jharrison5
Aug 19, 2015 05:53 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
