Need Advice For Modifying My Shift Governor
Old Apr 19, 2008 | 04:08 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I'm posting this for the future reference of other thirdgeners as well as for my own benefit.
I just installed a "Corvette" governor and I still need higher shift points. I had already bought the B&M spring and weight kit. I should have just modified my stock governor and saved the $50 I spent on the "Vette" governor. Oh well.
It now shifts 1-2 at 4,300 RPM and 2-3 at 5,000 RPM. I would like both shifts at 5,500 RPM.
Would anyone like to suggest, from personal experience, what to change first? Should I go one step lighter on one of the weights or should I change both weights to gain an additional1,200 RPM for the 1-2 shift? I hope the two shifts points even out a little.
Any comments would be appreciated.
Old Apr 19, 2008 | 05:28 PM
Max's Avatar
Max
Re: Need Advice For Modifying My Shift Governor
Here are the changes I made and the results:
I replaced one of the stock weights with the lighter B&M #4 weight (matched with the stock white spring)
The remaining stock weight was matched with the stock purple spring.
1-2 shift: 5,000 RPM
2-3 shift: 5,750 RPM
This change moved both shifts up about 700 RPM and spread the gap between shift points about 50 RPM. According to the B&M instructions, stiffer springs produce earlier more closely stacked shifts.
Next I'm going to replace the white spring with a second (stiffer) purple spring. Both springs should then be the same and this may reduce the gap between shift points.
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
