t5 swap ...now low pedal
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
hey guys spent the weekend doing a t5 swap in my 84 z28, any way its all back together, my problem is this
the pedal is very low as in it has to be to the floor to go into gear and reverse is really tricky(grinds), no noise or anything i bled the system like 200 times to no avail. (this included pushing the slave in and out with the cap off)
stuff ive verified
1 YES the thowout bearing is installed correctly (you dont have to post the pic) hehe
2 pivot ball is not backed out
3 no leaks (hydraulics)
now ive order a new slave, this whole setup is used and the slave is the easiest to replace so im starting there but any suggestion would be welcome
stuff ive verified
1992 Trans Am
May 10, 2023 07:19 PM
