700r4 Shifts?
Old Apr 21, 2008 | 01:50 PM
Iroc'nthe87's Avatar
700r4 Shifts?
when shifting from 1-2 at low speeds, it seems to stay in first for a little while longer than i expect it to and once it shifts, it throws the car forward. Advice? Thoughts?
Old Apr 21, 2008 | 05:49 PM
Re: 700r4 Shifts?
anyone home?
Old Apr 21, 2008 | 06:04 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: 700r4 Shifts?
Your TV plunger is internally sticking due to wear and/or sludge. Very common. If it does not free up driving it, a tear down is in order
Old Apr 21, 2008 | 06:18 PM
Re: 700r4 Shifts?
I mean if it recieves more throttle the shift is easier/smoother. Its just when putting along is jerks into gear. I dunno if that makes a diifference.
Old Apr 21, 2008 | 11:29 PM
squeeezer's Avatar
Car: 5 cars
Re: 700r4 Shifts?
do you know how to SET your t.v. cable????????
three pages of reading
http://www.tvmadeez.com/article/index.php
Old Apr 22, 2008 | 12:03 AM
84z350crate's Avatar
Car: 84 Z28
Re: 700r4 Shifts?
I just got a holley carb and can't perfect my tv cable too. I took it to a trans specialist and he says everything was shifting good. but it just doesn't seem right to me. Under light throttle it wont shift 1st to 2nd till 2200, that seem right?
Old Apr 22, 2008 | 10:21 AM
Re: 700r4 Shifts?
I'll have to read that later as finals are this week. Also, when i shift from park to drive it seems to engage rough as well, about the same way as the 1-2 shift when cruising.
Old Apr 22, 2008 | 02:13 PM
Pro Built Automatics's Avatar
Re: 700r4 Shifts?
The TV cable sounds like the problem here in both cases, too tight! Get the TV geometry correct, then all else should fall into place with the right setting.
Old Apr 22, 2008 | 07:28 PM
squeeezer's Avatar
Car: 5 cars
Re: 700r4 Shifts?
losing 3rd and 4th is what happens when your tv is not set right
#1 cause!!!!!!!!!
Old Apr 23, 2008 | 12:44 PM
Re: 700r4 Shifts?
T.V. Cable=SOLUTION!! haha thanks guys this is why I love the site.
Old Apr 26, 2008 | 10:48 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
Re: 700r4 Shifts?
hey im having same problem howd you set yours to shift right? mine aint shifting outta 3rd til 3000, but it just started doing it dunno y
Old Apr 27, 2008 | 10:30 AM
Engine: 355
Re: 700r4 Shifts?
anybody??
Old Apr 27, 2008 | 10:34 AM
Re: 700r4 Shifts?
follow link..might be your problem or might not be.
Old Apr 28, 2008 | 01:25 PM
Engine: 355
Re: 700r4 Shifts?
how do i tell if my 700r4 has a lock converter on it? its shifting at 3000 rpm to get to first. whats the correct way to adjust the tv cable?
Old May 2, 2008 | 11:12 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Re: 700r4 Shifts?
Old May 2, 2008 | 11:21 PM
BigBadJohn's Avatar
Re: 700r4 Shifts?
My car seemed to do this as well. Almost seemed like a hard nudge. Mine had 190K on it and was done for
Old May 5, 2008 | 12:25 PM
Re: 700r4 Shifts?
New problem: Shifts seem ok, but i dunno if ive lost a gear or not but when i start giving it more throttle and its pulling around 3g's it seems like its not pulling as hard as it should be? (Actually its def not pulling as much as it should, its like the trans cant keep up with the motor.)
Old May 5, 2008 | 02:50 PM
BigBadJohn's Avatar
Re: 700r4 Shifts?
Probably slipping really bad. Does it have much pick up and go? Can you brake torque?
Old May 5, 2008 | 04:22 PM
Re: 700r4 Shifts?
I mean it'll go but I definately think its slipping. It should def be pullin harder at those rpm's.
Old May 5, 2008 | 04:40 PM
BigBadJohn's Avatar
Re: 700r4 Shifts?
How many miles on the car and is it the original trans?
Probably needs a rebuild or another trans put in
Old May 5, 2008 | 05:04 PM
Re: 700r4 Shifts?
93k, and I believe its the original trans. Prob gonna be lookin for a new trans.
Old May 5, 2008 | 06:02 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Re: 700r4 Shifts?
Might want to check your fluid level and condition. Sometimes doing a fluid and filter change can do wonders for a tranny.
Old May 5, 2008 | 10:33 PM
Re: 700r4 Shifts?
Maybe the torque converter?
Old May 7, 2008 | 11:03 AM
fusion116's Avatar
Re: 700r4 Shifts?
#1 cause!!!!!!!!!
Thats what happened 2 me doing 80mph on the freeway!
Old May 8, 2008 | 12:41 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Re: 700r4 Shifts?
Funny how the only suggested solution is always:
First
Adjust the TV cable
Second
Rebuild the trans (even if it is a fresh rebuild)!!
Always start out with the correct adjustment of the tv cable, but it's not always necessary to do a rebuild.
Good luck trying to find someone who knows anything at all about the 700R4. It seems to be the one transmission that pretty much no one knows about.
I've been having the same problem with mine. I've posted many messages, searched many threads, talked to many different so called "tranny gurus" and every single resopond has started with these first two, then they were all completely different suggestions that ended with "take it back to where it was rebuilt". One guy (that was refered to me here) told me that it would cost $1100.00 for me to pull the tranny out of my car myself, and take it to him so he can take it apart, look at it, and then put it back together and tell me how much more $$$$ it would be to repair it!
Now, I'm not saying that there is no one in this gigantic world that knows anything at all about this tranny, just that I haven't found anyone yet.
Once again, Good luck.
Oh, and if you do find someone, let me know.
Old May 8, 2008 | 12:49 AM
Re: 700r4 Shifts?
For 1100, id just put that straight towards a new tranny. The adjustment I made on my TV cable did help with the slower speed shifts, so that was good. I'll prob just start to invest in a new tranny/tc once I have everything else taken care of. For now the trans will suffice as long as its treated right.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
