How hard is it to install a bolt on 12bolt from summit or hawksthirdgen
Old Apr 24, 2008 | 03:00 PM
79frankenstein's Avatar
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
Ok im new rear end issues, im getting ready to drop 450 HP and 460 TQ in my 86 z28 with a new TH350. Iv heard that the 10 bolt i have is a complete wast of time for that much power and it will just puke. Since iv never dealt with rear ends, i was wondering how hard installing a new 12 bolt will be. Will i have to pay someone to weld things into place, do i need special tools, and is this a good idea in general, or is life easy and everything just bolts into place......(high hopes)?
Old Apr 24, 2008 | 04:27 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: How hard is it to install a bolt on 12bolt from summit or hawksthirdgen
As long as its a bolt in rear end...thats all you'll need to do is just bolt it in. Relatively easy and quick.
Support it with a jack, unbolt shocks, lower control arms, sway bar, panhard bar, torque arm, and brake line. Don't worry about the springs, they will fall right out.
When re-installing it you may find it easiest to bolt up the torque arm first, that way you don't have to worry about rotating it forward or backward with something else attached to it which can get hard. Rear ends are quite heavy.
The only thing that could possibly need welding is if you decide to install lower control arm relocation brackets. But don't worry about these yet. Once you get the rear end all installed and get the car on the road you can decide whether or not you want them.
Old Apr 24, 2008 | 08:27 PM
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
Thanks sounds good. will my stock torque are work with a 12 bolt case?
Old Apr 24, 2008 | 08:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
it should work just fine
Old Apr 25, 2008 | 08:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
As long as you are using one of the aftermarket 12-bolt housings that were designed to be used in these cars, thats true.
It should go in the same way the 10 bolt came out. Reverse of disassembly. It MUST have the torque arm mount cast into the side of the center section to work - only the aftermarket ones will have this provision. You won't find one under a truck at the junkyard that will work.
Old Apr 25, 2008 | 08:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
true, i figured if he's getting a 12 bolt it would be one of the rears designed for our cars
Old Apr 26, 2008 | 10:09 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
it's easy as pie
Old Apr 26, 2008 | 03:19 PM
Air_Adam's Avatar
I assumed he would know too, but thought I'd say that just to make sure he knew about that little detail. Having been an automotive service advisor in a past life, I've met alot of really stupid people - and they are usually cheap to boot - bad combination when it comes to performance parts!
(PS - no offence 79frankenstien, I'm not talking about you, just people in general )
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
