Is it safe to roll...?
Old Apr 27, 2008 | 12:34 AM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Is it safe to roll my Trans Am without the torque arm attached to the transmission...as it doesn't have one. I've got to roll it, so I put my Moser 9" in with the UMI trailing arms, UMI panhard bar, Pro-Kit springs, and I've attached my stock torque arm for stability while it rolls. I just want to know if I secure the front of the torque arm with tie straps, will it be ok to roll on and off a trailer?
Old Apr 27, 2008 | 01:05 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Is it safe to roll...?
If by roll you just mean push it around, then yes it will be fine. Just don't drive it like that.
Old Apr 27, 2008 | 02:23 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Yes it is safe to roll. DO NOT DRIVER IT UNDER POWER.
Old Apr 27, 2008 | 07:45 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Well the motor and trans aren't in the car..I just need to move it.
Old Apr 27, 2008 | 10:50 PM
bnoble's Avatar
Car: '91 Firebird Formula
Engine: 383 w/ BW S400 turbo
Transmission: TH400
Axle/Gears: QP 9", 35 spline, spool, 3.15:1
You can move it no problem, just don't jerk on your e-brake hard while it's moving or anything.
86IROC112
Nov 27, 2015 09:54 AM
roysatikas
Sep 22, 2015 08:15 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
UMI Sales
Sep 4, 2015 08:39 AM
