Proper flexplate for ZZ4
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I need to know the proper flexplate for the ZZ4.
I need to have the small 152 tooth flexplate with the new crank bolt pattern and the proper counter weight.
I bought a flexplate for a 2000 camaro from the parts house which has the proper bolt patterns and the proper diameter. The counterweight consufuse me as it may only work with an LS1 or LT1. I did not think about this at the time and can take it back.
Reason for needed one...
I am running a lighweight flexplate with a 3 disk clutch and a thick aluminum bell housing / scatter shield that will only take a small flexplate / flywheel.
Last time at the track the car developed a noise in the bell housing. I believe the counterweight that bolts to the clutch pack came loose and going to a factory type flexplate with the weight welded on may be more reliable.
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: Proper flexplate for ZZ4
Flexplate's are for automatics
Flywheel's are for a manual transmission.
What one do you need?
I need a flex plate.
My clutch set up works with a flex plate.
The clutch disc is 7.25 inch and has its own flywheel which is also 7.25 and bolts to the crank through the flex plate.
Flexplates their not just for automatics. Think reduction in rotational mass.
Interesting.
I purchased a ZZ383. It came with a 153 tooth flexplate and I have a manual. If your interested I'll be happy to sell the brand new flexplate really cheep.
PM me if your interested.
Transmission: 4L80E/4L80E
Not to nit-pick, but it's either 153-tooth or 168-tooth.
Keep Nit Pickin!
Thats keeps us honest and on a learning curve!
Thanks I found what I needed.
Many folk say that I have been off by more than a tooth before
