Will My Trans Handel it??
Old Apr 29, 2008 | 09:01 PM
jjohnston's Avatar
Car: 91 Camaro RS
I have a 91 Camaro. It has the 700r4 trans. I recently put in an LT1 engine. Only thing done to the trans is a VSS, Reluctor, and a TCI Lockup Kit. I want to upgrade the gears to a 3.73 posi. I have had people tell me that My trans won't handel it. Will it or won't it? Anyone know for sure?
Old Apr 29, 2008 | 10:44 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: Will My Trans Handel it??
If the motor is mostly stock it will. The best 350 tpi made 245, the lt1 made 275 IIRC. I think the trans stock is good for about 350-400hp. Just make sure you have the TV cable hooked up correctly. If not, it'll blow real quick.
I think the LT1 needs a higher stall converter, but I could be wrong.
Old Apr 29, 2008 | 10:54 PM
jjohnston's Avatar
Car: 91 Camaro RS
My LT1 is in and workign great, I have been driving it for a year and a half now. I was just worried about weather the higher gears in the differential would caus an issue.
Old Apr 29, 2008 | 11:00 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
No, they will probably help the trans last longer, it won't slip as much, and is doing less work. If your worried about it, install a trans cooler, or a deep pan. Heat kills trannies.
Old Apr 30, 2008 | 09:34 AM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
The gears themselves won't kill the tranny. However I'm guessing if you did the transplant you have headers, exhaust and a couple bolt ons too. Unfortunetly an automatic transmission basically works by eating itself over time so evetually you will have to rebuild it. But the gearing change shouldn't adversly affect the life of your 700
Old Apr 30, 2008 | 06:37 PM
jjohnston's Avatar
Car: 91 Camaro RS
Thanks for all the good info. I do plan to replace my 700r4 with either a rebuilt one that is built up to handel more hp. or replace it with a 4l60e that has been built up to handel more hp. Because I eventually want to do new heads, cam, and exhaust to increas power up to hopefully around 400hp or more if possible. Funny... In hind site I should have just saved up for an LS2 ha ha. or LS6. Mmm yummy
Old May 1, 2008 | 01:29 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
You could strengthen/rebuild the trans yourself. I've heard its really not that bad if you buy a few tools. I think the kits are only around 400 bucks. I've never done it, but I want to!
I think the 60e would be a good choice since you could plug it right in. Don't have to worry about that stupid cable anymore.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
