Need help on BM megashifter
Old May 1, 2008 | 04:13 PM
BigBadJohn's Avatar
Okay. I just got a used BM megashifter for the 82-92 from a guy on nastyz28. Its an older model. I tightened up some bolts and its alot tighter now but still some play in the shifter when Im not pulling on the trigger
Also, is it supposed to be easy to shift directly from drive to neutral without going all the way to reverse or park, because it seems like I have to shift slowly from drive to neutral or Ill slam all the way to park.
There are a 1, 2, and 3 on the shifter display but It wont shift into that poition. Why would they put the numbers on there then?
Guy didnt have the BM red shifter cable so he said he made a bracket that you can use an oem style cable. Anyone ever done this?
I was wondering if I can get a full size scan of the cutout template that comes with these
Thanks for help in advance guys
Old May 1, 2008 | 04:34 PM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
Re: Need help on BM megashifter
There is no template that comes with them. Go to bmracing.com and you can download pdf of install instructions
Old May 2, 2008 | 02:18 PM
BigBadJohn's Avatar
What about the play in the shifter?
Figured out the shifting from drive and through the lower gears. Now I get what "ratcheting" means
Old May 3, 2008 | 12:03 PM
BigBadJohn's Avatar
Anyone know where I can find the boot and cable for cheap?
unknown_host
Aftermarket Product Review
Aug 11, 2001 08:44 AM
jayman350
May 18, 2001 08:23 PM
jimbo
Mar 14, 2001 05:35 AM
STL1994
Feb 17, 2001 02:41 AM
Fastbird
Nov 5, 2000 10:47 AM
