LT1 linkage in a T5
Old May 8, 2008 | 10:21 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
LT1 linkage in a T5
Hey all,
I have a 1990 WC T5 in a n IROC. My hydraulics are worn out and I can get a deal on a new set of hydraulics the catch is it is for a '97 LT1.
I like the braided line so want to install this setup.
does anyone know if there are any reasons why I could not completely replace my linkage with a set from a 1997 LT1 camaro?
thx
Old May 8, 2008 | 11:05 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: LT1 linkage in a T5
I think the only difference is going to be the length on the line but a lil extra is fine just tie it up out of the way if it looks like it will get in the way of anything
Old May 9, 2008 | 08:21 AM
palric's Avatar
ttt
anyone else?
please chime in if you have experience in this area.
thx
Old May 10, 2008 | 09:28 AM
Stevo's Avatar
Car: Pair of 92 Z28s
Yup, the slave cylinder on the t56 mounts the opposite way because it is a pull style throwout bearing. So the line is longer.
Like said above just tie or tuck the line out of the way and you should be good. I'm using a T5 with LT1 hydraulics.
Old May 10, 2008 | 12:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im using the lt1 setup too, works fine. the only little issue is the open end of the master pushrod that attaches to the clutch pedal is a little thinker or something, the stock retaining clip for the t5 setup wont work, you need to use something else. Im using a e-clip retainer, works fine
Old May 10, 2008 | 09:15 PM
palric's Avatar
appreciate the info
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
mfp189
Sep 27, 2015 09:25 AM
L0tuS
Sep 4, 2015 11:16 PM
