Automatic Shifter Loose
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
I noticed when I took the car for a test drive after installing the Hedman Longtube headers that when I was just cruising and getting ready to punch it for a WOT throttle, the shifter was loose when I was in any gear. There was alot of play. Can anybody tell me whats wrong and how it can be fixed?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Automatic Shifter Loose
get under the car and check the linkage bolted to the trans pan.
Car: 92 Camaro
Axle/Gears: S60 373
how should it fit? What exactly am I looking for?
Car: 86 Trans Am
see if its come unbolted, its seems to be a common issue. It bolts to the pan, make sure that bracket is tight, and make sure that the bolt in the linkage it there/tight as well.
Car: 92 Camaro
Axle/Gears: S60 373
Alright, I hope this is it. This would save me money instead of getting an aftermarket shifter.
