stock rear end to 3.42 rear
Old May 11, 2008 | 09:34 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
Axle/Gears: 3.42 posi
hey, not sure if ive got the right board for this but i have a question that id appreciate some help with. i have a 90 camaro rs with the stock 2.73 rear end with brake drums. my friend has a 3.42 posi disk brake rear that he wants to sell me but i dont know how to put it on my car. is this a hard thing to do?
Old May 11, 2008 | 10:13 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: stock rear end to 3.42 rear
What car is his rear end from?
Old May 11, 2008 | 10:20 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
It's very simple,if the other rear is from a 3rd gen.
Old May 11, 2008 | 10:38 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
yes the other rear is from a 3rd gen. its from a firebird gta i believe
Old May 12, 2008 | 01:36 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
It is a direct bolt in replacement, with the likely exception of brakes and emergency brake, which depends on some things like the year of the car the rear end came out of. These problems are likely easily solved. Scouring the archives here should lead to some answers which I don't have right now...
Old May 12, 2008 | 06:51 AM
squeeezer's Avatar
Car: 5 cars
just research for speedo drive and driven gears online (also easy to do)
maybe a sticky here???
ill be doing the same any day now from 3.23 to 3.73
Old May 12, 2008 | 11:40 AM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
well the new end is coming out of a 91 forumla. is the e brake thing a easy thing fix after the switch. are there any walkthroughs here or anywhere else for the swap? what kind of problems will i run into while doing this swap and after the swap has been done?
Old May 12, 2008 | 11:01 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
bump
Old May 12, 2008 | 11:11 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You'll need to change the speedometer gears. IIRC, 17 tooth and 41 tooth.
I have a 1LE prop valve to install when I do my drum to disk swap, but I dunno if it is absolutely necessary. I have seen someone else do the swap without swapping the prop valve and get away with it.
And you'll need the parking brake cables.
Look around here, or even better, do a search. This has been covered a million times.
Old May 14, 2008 | 06:53 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
well i did a lot of research and such here on the site. ive gotten my new gears and im in the process of installing them. ive gotten everything out except the pinion. whats the best method to remove the pinion so i can put in the new one.
Old May 14, 2008 | 10:28 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Are you replacing the gears by them selves or the whole rear end?
Old May 14, 2008 | 11:45 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
yea im just replacing the gears. any idea off hand wut size the bolt is that is holding on the driveshaft yolk?
Old May 15, 2008 | 09:46 AM
krisb410's Avatar
I would have just change the whole housings off that car onto yours.
Old May 15, 2008 | 05:29 PM
92RS702's Avatar
Car: 92RS
If you replace the entire rear diff you'd have an LSD and disc brakes.
Old May 15, 2008 | 11:26 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
ive gone ahead and changed the gears. went pretty well. definetly a better pickup and quicker acceleration. speedometer is off now and i hope to fix that soon as well. one lil issue, when i drive im hearing a small winning noise. my guess would be that i need a few more shims to one side or the other. anything else that could cause this. i dont wanna wear these gears out.
Old May 16, 2008 | 09:53 PM
skifur555im666's Avatar
Car: 91 t/a gta
Engine: 383
Transmission: t-56
Axle/Gears: moser/auburn/410
bump
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
